190 cosworth body panels
shindy
north lanarkshire
porsche cayenne,white c63 amg
hi guys,
doing a bit of restoration on my cosworth..need both side outer wheel arches and both side rear quarter panels.....any help appreciated.
shindy
If it's any help as far as I'm aware they are the same panels as a normal 190E except the 1/4 panel (front wings too) come pre-drilled to accept the wheel arch body kit mouldings.
Do you mean the Cosworth body kit rear wheel arches or the actual metal wheel arches?
yes ...been told that ,when done will put the wheel arch trim glued and sealed instead of clips to stop water ingress again..
Yep, bonded is the way to go. I had both front wings replaced on my previous 16v and used standard wings and bonded the w/arch moulding on. Still all good to this day afaik.
got the parts now thanks
