geoff evans
- Sep 4, 2014
- r129500sl
Hi there I have a 1991 500sl it has been dry stored for 12 months, I have drained all the old fuel fitted a new fuel filter It does not seen to have any fuel in the injector lines fronm the fuel distributor there is fule in the main feed and return lines to the distributor, fuel pumps are working. prior to draining the old fuel and fitting the new fuel filter it did fire up and try to start a couple of times, it also runs up with easy start , ant ideas would be much appreciated thanks.
