honalulu
I have had problems with starting the c250. All the plastic fuel pipes have been changed but still a problem. So I removed the fuel shut off valve and replaced the O ring at the rear of the valve and removed the primer pump to check the non return valve which drained the injector pump. Now I need to refill the injector pump with oil but I am not sure how and to what level. Urgent help needed please.
