RichardF
- Aug 24, 2013
- Sl 320
Fine one day, then idle went awol and misfire started, felt like 2 cylinders but may have been one. Total mileage driven with miss about 4 miles.
Took car home and left it, whilst errands run in spare car.
Several hours later I started it miss still there, I ran a diagnostic blink code, none found. Whipped the plugs out, all looked okay, fitted an old set of Bosch resistor plugs (320 should use non resistor plugs) found in the bottom of my tool box. All fine engine runs smoothly again.
The plugs I took out were Bosch 18k miles 3 yrs. Ordered some NGK, which I'll fit next week when I service the car.
Questions
I've never had a plug fail suddenly before (except old 2 strokes!!) just a gradual drop off, if this is going to happen I need to carry spares?
A chap on a USA site reckons the coils, leads and extenders are consumables and should be changed periodically, is this so? I've notice a huge disparity in coil prices from around £17-£120 (the 320 uses 3). What would be recommended? Would a failing coil or lead show up on a blink code reader?
I use the car for touring and continental trips, breakdowns would be a right faff (fortunately not many problems in the last 4 yrs) and not endear me to Mrs F. So while happy to carry out preventative maintenance, I don't want to chuck money @ stuff that's perfectly okay.
The upper engine/TB/lower engine, wiring harness was replaced 2 yrs ago (a problem on this year) due to failing insulation.
Questions
