kimjenkins
- Jul 2, 2010
- Location
- Bodmin, Sunny Cornwall
- MB E320 CDI Estate 2002 --- Saab 93 Turbo Convertable
If anyone can help please.....
I have a 2002 E320 CDI estate that seems to have a few problems.
1st problem:
First noticed the car lurching into 1st gear only, but when the engine was stopped and re-started it was fine untill one day when it just stayed in first gear no matter what I did. So I took it to the MB dealer and had it plugged in. They said that it showed a multitude of faults that where mostly unimportant, the main fault was 'charge air pressure low' , Inspect charge hoses and inspect turbo wastegate linkage. Checked VAC hoses, undable to fault on roadtest. So they cleared the faults and the car was fine again.
My brother used to be a machanic (unfortunatly no longer) so i asked his advice and he suggested that the gear problems could be electrically related ...... infact if I put the battery on charge for a few hours the gear problem doesnt happen ..... just the second problem below!
2nd problem:
Its lost alot of power ..... it moves through the gears alright, but has no kickdown when in D.
I have been searching the forum for days and have seen other posts of similar problems. One suggested cleaning the MAF sensor (which was really easy and took only 15mins) I have also changed the air filter and fuel filter. <------ me
If anyone has any advice i could really do with it!
Many Thanks in advance
kimjenkins
1st problem:
2nd problem:
kimjenkins
