2003 clk 240 w209 - amp power feed
craig-
clk 240
Hi. Can anyone direct me in the best method to run a power cable from the battery through the bulkhead? I removed the battery but couldn't see any obvious path. Thanks
Is there another way to power a boot mounted amp, other than straight from the battery
Depending on the power of the amp is there a rear mounted fusebox with a substantial supply cable?
Thanks for the reply. It's only a small amp. That would simplify the install.
Back of the battery tray, through to the passenger foot well via the rubber gromits. I did it, tricky but the cleanest way.
