2006 Vito 109 639 engine failure
MCHammer89
Vito
1st case-Instrument cluster would jump and limit the revs, clicking sound in the dash when the air con is on and does not work the same time it is happening to the instruments.
2nd- While driving engine light comes on then loses power before engine shuts down, can coast, turning ignition off then on to restart straight away. Progressively got worse within 3 days.
3rd-Workshop has replaced ignition harness to start the engine only but didn't resolve case 1&2. ECU then sent away to be replaced and programmed.
4th-Replacement ECU installed worked for 20 mins then engine shuts of and unable to start.
