2006 Vito 111cdi - Stiff Clutch
wu56Shoozz
You'll need a passport to get over the Wall..
MB Vito 111CDi / W203 C Class Saloon 320CDi Avantgarde
Okay,
I'm getting the hang of this new found beast.. but I've noticed that I've a stiff clutch, creaks on the pedal a bit... should I be worried? I've had it checked by a mechanic who advises its fine biting point is where it should be but I just wonder is it the springs in the clutch that are going that will cause the inevitable failure or are they all heavy?? :dk:
Mine was heavy. The only solution was to change is and the duel mass flywheel.
