I'm experiencing an annoying problem with the end cap on the indicator arm falling off. Luckily at the moment I've not lost the inner spring.
I've tried using double sided sticky tape so the next option I'm considering is using Super glue to retain the end cap.
I imagine this is be a common problem & my question is has anyone glued the end cap on ?
How did you fix the problem ?
Thanks in anticipation
