jellafish
Anybody used the kits for drilling out seized glowplugs that are advertised on ebay for about £100,i have been charged £50 a plug to remove,which mercedes contracted out to a specialist to do the work.
Try and unwind the glowplug wearing GOGGLES, THICK LEATHER GLOVES and be ready for it to "fire" when it shoots out. Spraying WD40 as you on onto the plug.
Basically fires out like a bullet. Dive out the way as you see it loosen up....
inlet manifold has to be removed to replace the glow plugs, its an easy job. The 4 torqs bolts that secure it to the EGR housing are a bit fiddly and are accessible from under the engine.
