270cdi head
colin1969
mercedes ml 270 cdi
hello this is my first post i have a 2002 mercedes ml 270cdi and have just had the head skimmed by 12 thou i need to find out if i have to get an over sized head gasket thanks
Why did you have it skimmed? Can you post up your chassis number and I will check for you.
Sorry for late reply been away I had 12 thou taken of done the inlet mod all back together now runs great apart from I think it's gone into limp mode won't change out of second gear fault codes coming up are 1/ p1354 sync between crank and cam sensor 2/p0400 bank 2/3 (hot film mass air sensor) signal voltage to low it was fine before I stripped it is there a fuse for all these I have plugger the wiring back into the swirl flap motor any ideas would be appreciated thankyou
Exact codes
P1354 synchronisation between crankshaft and camshaft no crankshaft signal
P1354 synchronisation between crankshaft and camshaft plausibility
P1354 synchronisation between crankshaft and camshaft no camshaft signal
P0100 bank 2/5 (hot film mass airflow sensor)the signal voltage to low
