grober
MB Master
Interesting little video clip on tyre tread depth on the autoexpress site. http://www.autoexpress.co.uk/ Evidently 3mm is minimum tread depth for decent grip in wet conditions. watch the video and make your own mind up.
All tyre manufacturers say 3mm, or 10 years, whichever comes firstBrian WH said:Very interesting and even more reason why I changed my tyres recently, despite forum members saying I shouldn't have done.
...and AGE of the spare.Satch said:• Finally, don’t forget to check the pressure and tread depth of your spare tyre.
You're not 100% correct there, the handling of my car is great with the front centres at about 2mm! Steering is sharp and precise, the tyres are quieter and I feel every tiny bump and piece of grit because the rubber doesn't absorbe it.C240Sport97 said:low tread depth also materially and adversely affects quality of the ride, handling and noise levels.
when I put on 2 new rear tyres recently, it transformed the car .. I had not noticed the gradual deterioration until 1 day it struck me that the car was feeling a bit 'worn out'
Shude said:You're not 100% correct there, the handling of my car is great with the front centres at about 2mm! Steering is sharp and precise, the tyres are quieter and I feel every tiny bump and piece of grit because the rubber doesn't absorbe it.
Sadly I have to replace them. The rears are still good though, they'll prolly end up back on the front again...
