Paul64
- Jun 13, 2003
- Location
- South of France
- 1995 W124 E300 Diesel estate (250k miles), 2008 CL63 AMG, 1969 Triumph 2.5PI, 1975 Triumph TR6
Trusting all had a grear new year evening and the headaches are not too bad today?
For us, Christmas and New Year over, 1300 miles completed and time for another service - 260k km on the W124 300D-24v now and a few extras due to be done.
A superb car for the trip up to the North East of France via Switzerland - on the way back, I think it's the A26 South past Milan, we kept up between 110-115mph for about 25 mins on an empty motorway with great surface and clear skies and still managed 33mpg for the whole journey in mostly negative temps.
During the return journey home, I started to get a buzzing from the gearlever so today during the service, I changed out the bush in the linkage at the bottom of the lever.
As previous posts mention, it was a bit of a pain to fit without a special tool so I made one up with a long bolt and nut, a couple of washers and a short length of copper pipe as suggested but didn't go as far as using epoxy to centralise the pipe. Once that was done, the bush was fitted in 2 mins. The hardest part was getting the cables back in place at the side of the lever....
Hopefully, that will be the end of that as it was more than a little annoying over an 8 hour drive!
I want to replace the sump gasket perhaps this time the oil is drained. There's a small leak that's persisting and getting me told off by the Mrs.... I'm 99% sure it's the sump and have done a few other leaks higher up before picking up a new gasket yesterday.
I had a quick look and it appears that the anti-roll bar has to come off - does the damper have to come off the crank nose too allowing the sump to come forward and down?
Any hints on this job? It looks reasonably straight forward otherwise? Is it worth trying to retighten the bolts before doing the job or not worth the bother??
We had the air vents shut off for a while following an old truck over the mountains and when the system was back in operation, I got a whiff of coolant - could this perhaps be from a failing heat exchanger I wonder? Certainly, the car has been losing a small amount of water over the last few months - a litre since November perhaps - with no obvious signs of external leakage once the new radiator was fitted.
I know the A/C evaps tend to fail sometimes, is this the same with the heater matrix?? If so, I see big job on the cards this year then I suppose??
Looking forward to hearing from anyone up and about this 1st of Jan!
Paul
Paul
