Will the key blade fully enter the lock and turn in the key hole to the left or to the right?
Some useful info here… Bert Rowe's-Mercedes-Benz 'A'-class info. 5th Door (Boot Lid Locked, Jammed Closed)
Dec
I can absolutely confirm it is very easy to replace the whole lock, no need to remove lining for that - I did that myself (and I'm pretty useless with mechanical stuff) on my old 2001 W168, almost right after I bought it, as the old lock would only engage one out of ten attempts.
I believe the new lock cost me about £65 from MB Northampton, but that was nearly five years ago ...
As above - check the vacuum pipe / diaphragm first, it might be just that.
I may be wrong but I think that what you replaced was the latch mechanism, the OP is referring to the key lock.
I fitted a new latch to mine when I rebuilt the lock. Paranoid about the boot being jammed shut as mentioned by Lofty. The latch is less than £20.
No idea whats happened, but boot won't lock when using central locking or the key. Any ideas? Its a 1999 A160.
When it opens the alarm does sound, if that helps
