Acronyms of Diagnostic Codes
scorpie
Cork, Ireland
C180 Classic W203 A/T
Hi All,
I hope this helps to decipher the DTC's codes you may get,
Regards,
Scorpie
Mercedes-Benz Technical Acronyms
These acronyms are related to Mercedes-Benz vehicles. You can see these acronyms
while using diagnostic software and automotive diagnostic tools like OBD scanners or other
equipment.
4MATIC – 4 Wheel Drive
TC – Transmission Control
A/C – (Automatic) Air Conditioning (Automatic)
A/C – (Tempmatic) Air Conditioning (Tempmatic)
AAC – Automatic Air Conditioning
AAM – All Activity Module
AB – Supplemental Restraint System (Airbag)
ABS – Anti-lock Brake System
ACSR – Automatic Child Seat Recognition
ADM – Automatic Dimming Inside Rearview Mirror
ADS – Automatic Damping System (Suspension)
AIR – Secondary Air Injection
AKR – Anti-Knock Regulation
AP – Accelerator Pedal
APS – Auto Pilot System
AS – Antenna System
ASD – Automatic Locking Differential
ASR – Acceleration Slip Regulation
AT – Automatic Transmission
ATA – Anti-theft Alarm System
BA – Backup Assist
BARO – Barometric Pressure
BCAPC – Barometric Pressure-charge Air Pressure Compensation
BDC – Bottom Dead Center
BM – Base Module (Master Ecu Controller)
BPC – Barometric Pressure Compensation
CA – Closing Assist
CAN – Controller Area Network
CC – Cruise Control (Tempomat)
CCM – Combination Control Module
CDC – Cd Changer
CF – Convenience Feature
CFI – Continuous Fuel Injection
CKA – Crank Angle
CKP – Crankshaft Position
CL – Central Locking
CLUS – Instrument Cluster
CMP – Camshaft Position
CNS – Communication and Navigation System
CST – Cabriolet Soft Top
CTEL – Cellular Telephone
CTP – Closed Throttle Position (Idle)
CTU – Central Triggering Unit
DAS – Driver Authorization System
DFI – Electronic Distributor-type Fuel Injection
DI – Distributor Ignition System
DM – (USA) Diagnostic Module (Emissions)
DTC – Diagnostic Trouble Code
EA – Electronic Accelerator
EAG – Electronic Automatic Transmission Control
EATC – Electronic Automatic Transmission Control
EBR – Engine Brake Regulation
ECL – Engine Coolant Level
ECT – Engine Coolant Temperature
EDC – Electronic Diesel Control
EDR – Electronic Diesel Regulation
EDS – Electronic Diesel System
EDW – Anti-theft Alarm System
EFP – Electronic Accelerator
EGR – Exhaust Gas Recirculation
EGS – Electronic Transmission Control
EI – Electronic Ignition (distributorless)
EIFI – Electronic In-line Fuel Injection
EL – Exterior Lighting
EMSC – Electric Mirror, Steering Column Adjustment, Heated Mirrors
EPC – Electronic Power Control
ERE – Electronic In-line Fuel System
ESA – Electric Seat Adjustment
ESC – Electric Steering Column Adjustment
ESCM – Engine System Control Module
ESP – Electronic Stability Program
ETC – Electronic Transmission Control
ETR – Emergency Tensioning Retractor
ETS – Electronic Traction System
EVAP – Evaporative Emission Control System
EVE – Electronic Distributor-type Fuel Injection
EZL – Distributor Ignition System
FAN – Fanfare Horns
FFS – Frame Floor System
FOM – Folding Outside Mirrors
FP – Fuel Pump
GIM – Governor Impulse Method
GM – Base Module (Master Ecu Controller)
HAU – Automatic Heater
HCS – Headlamp Cleaning System
HEAT – Automatic Heater
HFM – Hot Film Engine Management
HFS – Hands Free System
HHT – Hand Held Tester
HM – Heated Mirrors
HORN – Horn Signal System
HS – Heated Seats
IAT – Intake Air Temperature
IC – Instrument Cluster
IDC – In Dash Controller
IFI – Electronic In-line Fuel System(diesel)
IFZ – Infrared Remote Central Locking
IL – Interior Lighting
IR – Infrared
IRCL – Infrared Remote Central Locking
IRM – Inside Rearview Mirror
ISC – Idle Speed Control
KE – Continuous Injection System (Cis)
KFB – Convenience Feature
KI – Instrument Cluster
KLA – Air Conditioning
KS – Knock Sensor
KSS – Knock Sensor System
LH – LH Sequential Fuel Management Bank 1 (1-6 or 1-8 Cylinders)
LH2 – LH Sequential Fuel Management Bank 2 (7-12 Cylinders)
LHS – Left Hand Steering
LLR – Cruise Control
LOC – Low Compression
LS – Loudspeaker System
MAF – Mass Air Flow
MAP – Manifold Absolute Pressure
ME – Motor Electronics
MIL – Malfunction Indicator
Lamp – (Check Engine)
MSC – Mirror, Steering Column Adjustment, Heated Mirrors
MT – Manual Transmission
MVA – Manifold Vacuum Assist
MWH – Main Wiring Harness
NS – Network System (CAN)
O2S – Oxygen (O2) Sensor
OBD – On-board Diagnostics
OC – Oxidation Catalytic Convertor
OCP – Over-head Control Panel
ORM – Outside Rearview Mirror
OSB – Orthopedic Seat Backrest
PL – Power Lock
PML – Speed-sensitive Power Steering
PMP – Partial Intake Manifold Preheater
PNP – Park/neutral Position
PS – Power Steering
PSE – Pneumatic System Equipment
PTS – Parktronic System
PW – Power Windows
PWM – Pulse Width Modulation
RB – Roll Bar Control
RCL – Remote Central Locking
RD – Radio
REST – Residual Engine Heat Utilization
RHR – Retractable Rear Head Restraints
RHS – Rear Heated Seats
RPM – Revolutions Per Minute (Engine Speed)
RST – Roadster Soft Top
RTG – Retractable Trunk Lid Grip
RTR – Remote Trunk Release
RV – Roadster Soft Top
RWD – Rear Window Defroster
SBE – Seat Belt Extender
SLO – Starter Lock-out
SMS – Service Microfiche System
SOR – Seat Occupied recognition
SPS – Speed-sensitive Power Steering
SR – Sliding/Pop-up Roof
SRS – Supplemental Restraint System (Airbag)
STH – Stationary Heater
TB – Throttle Body
TC – Turbo Charger
TCM – Transmission Control Module
TD – Speed Signal (Time Division) (EZL)
TDC – Top Dead Center
TIC – Transistorized Ignition Control
TN – Speed Signal (EZL/AKR)
TPC – Tire Pressure Control
TRAP – Trap Oxidizer
TS – Towing Sensor
TVV – Tank Ventilation Valve
TWC – Three Way Catalytic Convertor
ÜRB – Roll Bar Control
VAF – Volume Air Flow
VSS – Vehicle Speed Signal
WOT – Wide Open Throttle (Full Load)
WS – Wiper System
Is there a similar acronym list for COMAND? None of the acronyms in the enclosed screen shot are in the list above. If not, can someone explain the acronyms? (HU=Head Unit, TV=TV and Navi=SatNav is clear)
Desperately need to know the part number
:wallbash:My apology if I am asking this question in the wrong place. It is my second posting & still can't find the "sticky post in the new members" but I am hoping that you forgive this. I desperately need to know the part numbers for xenon control unit & ignitor for CLK200K elegance 2003 (WDB209342) with HID factory fitted. Also if you know the Bosch OEM equivalent part number. Many thanks
Just a small point
ADS = Adaptive Damping System (not "Automatic")
Help 911!!!
Need help with nfinding out the reset stereo code after replaceing battery and cant locate manual, someone help?
:wallbash:
how do i unlock stereo???2000 mercedes UT (new battery)...lost here
The nearest dealer will help...proof of ownership will be required.
Can i ask a question about a a190 bas asp problem?
Hi All,
Regards,
Scorpie
equipment.
AS – Antenna System
BA – Backup Assist
CA – Closing Assist
CDC – Cd Changer
CKA – Crank Angle
FAN – Fanfare Horns
FP – Fuel Pump
HM – Heated Mirrors
HS – Heated Seats
IR – Infrared
KS – Knock Sensor
MAF – Mass Air Flow
PL – Power Lock
PS – Power Steering
PW – Power Windows
RD – Radio
TB – Throttle Body
TC – Turbo Charger
TS – Towing Sensor
WS – Wiper System
Great post, Skorpie. Thanks.
Nice one was wondering what ASR was
