Active bonnet management mafdunction w212
Discussion in 'Bodywork' started by ozthecoz, Jun 6, 2013.
  1. ozthecoz
    ozthecoz New Member
    19
    May 5, 2013
    Just had the active bonnet management function warning flash up on my dash board.
    I've had no bumps or crashes and it came on whilst driving.
    Can anybody shed any light on this ? Is it safe to drive ?
    Car is a w212 220 Cdi e class.
    Dave
  2. OP
    OP
    ozthecoz
    ozthecoz New Member
    19
    May 5, 2013
    Interestingly enough the message cancelled after approx 10 miles of driving and is not stored in the service / alert part if the menu
    Hmmmmm ?
  3. OP
    OP
    ozthecoz
    ozthecoz New Member
    19
    May 5, 2013
    And it's back again.
    Any comments ?
  4. grober
    grober Hardcore MB Enthusiast
    22,289
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    The active bonnet system comprises three impact sensors in the front section of the car and special bonnet hinges which are pretensioned and locked into place with strong springs. The sensors signal a collision with a pedestrian to the electronic control unit, which immediately activates two electromagnets in the hinges. These electromagnets release the lock, allowing the spring action to raise the rear of the bonnet by 50 mm. This whole process takes only a fraction of a second.
    I would suspect some form of intermittent electrical glitch causing a fault to be registered. Quite possibly a known "gremlin" your MB dealer should be able to assist may------- just require a minor adjustment.
    edit :---there is a reset procedure evidently------- http://www4.mercedes-benz.com/manual-cars/ba/cars/c204/en/overview/motorraum9.html
    1 person likes this.
  5. OP
    OP
    ozthecoz
    ozthecoz New Member
    19
    May 5, 2013
    Shall have a look at that in the morn though I think an electrical gremlin sounds about right as the warning went again pretty soon after and snt showing.
  6. gmahadew
    gmahadew New Member
    1
    Dec 4, 2016
    Car:
    E coupe 350cdi
    Hi Any News about this? i've found a reset procedure you can DIY, pretty easy but did not work for me .. so hoping you guys have some new insights
    Verstuurd vanaf mijn Nexus 6P met Tapatalk
Share This Page
