advice needed on turbo conversion idea on W203 C180 2.0L
Discussion in 'Engine' started by tdh-syorks, Apr 17, 2012.
  1. tdh-syorks
    tdh-syorks Active Member
    84
    Jul 31, 2009
    Sheffield, England
    Car:
    2002 W203 C180 2.0, 1988 W201 190e 2.6, 1993 VW Polo G40
    had a thought about doing a turbo conversion to my C180 which I have owned for the past 9 years. Since I was looking at p/x for a E320 cdi the value of my car isn't worth much via trade in. So I've decided to keep the old bus and still get a E class.
    I have done conversions before on Volkswagens but never touched the Mercedes engine in that way.
    The engine in mine is the M111 2litre.
    Can anyone tell me which turbo would work, would a k03 be ok or a Garrett??
    Has anyone on here successfully done this and finally could anyone give me a fully itemized list of what's needed..
    I know people might just say what's the point, but I just want a bit of a project to keep myself occupied.
    Cheers Tom
  2. NW_Merc
    NW_Merc Banned
    5,918
    Sep 3, 2005
    Over here, sometimes over there
    Car:
    1994 Mercedes C180 classic
    The M111 is a pretty strong engine block (particularly the 230 kompressor block). I am going to be turboing (is that the correct word?) my car which has a similar M111 engine to yours, albeit in a much earlier model.
    It would be best to fit standalone engine management, however this isnt possible because of the stock ECU and wiring being tied into so many things. Hence I am looking at the following:
    1. Mosselman manifold
    2. Garrett T3 turbo (A/R 42) - the reason for this is for faster spooling times. The larger the turbo as you well know, the bigger the lag. It is the same as used in Ford Turbos.
    3. Copper 'spacer' head gasket to reduce compression - I havent got this yet, but a company called Ferriday Engineering Ferriday Engineering make these for performance engines. If you have deeper pockets you could get dished pistons made up with custom con-rods.
    4. 5th injector and driver (independently mappable to control fuelling levels)
    5. MAP sensor
    6. Intercooler and piping - I will be taking it off one of the kompressor models
    7. Adjustable fuel pressure regulator
    8. NGK spark plugs - iridium - one heat range cooler than standard
    9. Various lengths of tubing/hoses for oil and coolant connections to the turbo along with connection pieces.
    10. Gauges for boost and oil temp
    I think I'll have more of an idea of what I need once I start.
  3. OP
    OP
    tdh-syorks
    84
    Jul 31, 2009
    Sheffield, England
    Car:
    Great help, I'll start looking for manifold first, my mate has a spare Garrett T3 off his cossy.
    yeah I understand about the spool times etc, I didn't want anything too big, just enough to make it pull better than it is at the moment.
    T3 should take it to near 200bhp shouldn't it?
  4. NW_Merc
    NW_Merc Banned
    5,918
    Sep 3, 2005
    Car:
    Easily, but in terms of the manifold, the Mosselman one is quite rare and very expensive from Mosselman. You may need to consider fabricating your own or looking for companies that will make one for you.
  5. Howard
    Howard Hardcore MB Enthusiast
    18,624
    Apr 23, 2004
    Toad Hall
    Car:
    CLS 500 / A 150
    Send a PM to Koolvin the forum owner , he turbo'd a C180 years back.
  6. NW_Merc
    NW_Merc Banned
    5,918
    Sep 3, 2005
    Car:
    I think he's still got a Mosselman turbo kit for sale, which may bolt straight onto your car.
  7. OP
    OP
    tdh-syorks
    84
    Jul 31, 2009
    Sheffield, England
    Car:
    Niceone, I'll drop him a pm.
    If the mosselman manifold is unavailable I'll fabricate my own no problem.
    Cheers
  8. Bobby Dazzler
    Bobby Dazzler Hardcore MB Enthusiast
    13,204
    Jan 21, 2005
    Mittel England
    Car:
    Turbocharging.
    Thinking of the right word is easy when you're reading, but not so when you're typing!! :D
    Two turbo projects at the same time - sounds like fun.
    1 person likes this.
  9. andavaka
    andavaka Member
    37
    Apr 16, 2012
    ZA-Benoni
    Car:
    W203 C180 Nat.Asp. & POLO 9N3 TDI 96KW
    Intresting as i have also been looking at doing a similar conversion, please keep update.
  10. NW_Merc
    NW_Merc Banned
    5,918
    Sep 3, 2005
    Car:
    Well still acquiring parts at the mo'. Have already got the Mosselman manifold, Garrett T3 turbo, HKS SSQV dump valve and front AMG brake calipers. Will need to get a hold of a 5th injector set up and then I'll need to talk to Ferriday about their copper head gasket spacer.
    I think the adjustable fuel pressure regulator is not needed if you have the mappable injector set up.
    2 people like this.
  11. OP
    OP
    tdh-syorks
    84
    Jul 31, 2009
    Sheffield, England
    Car:
    Id rather try and get hold of a manifold rather than make one but if that's what it comes to then I'll have to. My mate said he's got a brand new Garrett t3 for me and I can have it for £300. Gonna pick it up at weekend :D
  12. NW_Merc
    NW_Merc Banned
    5,918
    Sep 3, 2005
    Car:
    My manifold was off a fellow member who was thinking of twin charging his 230 kompressor but then decided to sell the car instead. The Mosselman manifold was £250. Then the T3 turbo was £60.
  13. Beno
    Beno Hardcore MB Enthusiast
    343
    Aug 4, 2011
    Essex
    Car:
    C350 CDI
    Gents I seem to remember turbo charged engines run a lower compression ratio to a normally aspirated. It would be worth checking
  14. NW_Merc
    NW_Merc Banned
    5,918
    Sep 3, 2005
    Car:
    Yes I agree with you completely and for this reason there is one of 2 solutions:
    1. Fit a copper head gasket 'spacer', the thickness will be worked out by Ferriday Engineering and their calculations
    2. Fit dished pistons with stronger con-rods - more expensive but still a possibility.
    At the moment it is the time for research and gathering knowledge. I have never done this, and although it is something I am seriously considering, it would be best to fit correctly first time that have to take it apart and refit which would cost more money.
    I know that Koolvin fitted the MF2 injector controller with a subaru MAP sensor and 5th injector. On some forums the MF2 is considered a primitive set up, but there really isnt the possibility to add standalone engine management though this would be better in terms of fuelling.
    So my question is, does anyone have any suggestions on using a reliable additional injector set up?
  15. NW_Merc
    NW_Merc Banned
    5,918
    Sep 3, 2005
    Car:
    Now in a quandry on deciding to go on piggyback ECU + 5th injector or upgrade the existing injectors to 4 larger injectors and remap the stock ECU...... don't know yet whether the second one is possible...:dk:
  16. NW_Merc
    NW_Merc Banned
    5,918
    Sep 3, 2005
    Car:
    Has anyone got a diagram or picture of a 230 kompressor engine? Mainly to have a look at how the pipework meets the intercooler.
    Failing this, is there anyone in the North or North West with a kompressor either slk, clk or c class W202 or 203 which I can have a look at, just the engine bay. Thanks.
  17. NW_Merc
    NW_Merc Banned
    5,918
    Sep 3, 2005
    Car:
    Ideally, the link below shows what to aim for. The guy has used an SLK 99 Kompressor engine and has used a DTA S60 EFI system. I'm assuming this has replaced the original ECU for the car.
    Is it possible for the standard ECU to be removed and replaced completely? :dk:
    http://190rev.net/forums/showthread.php?t=29938
  18. andavaka
    andavaka Member
    37
    Apr 16, 2012
    ZA-Benoni
    Car:
    I personally think the 2nd option should be possible and more easier to do.
    Good luck with this i have also started collecting my plumbing and will start my thread soon.
  19. NW_Merc
    NW_Merc Banned
    5,918
    Sep 3, 2005
    Car:
    I've been looking at remaps, I think it may well be easier adding additional injectors and a piggyback ECU to co-ordinate with the standard ECU, as I think remapping may well lead to further problems down the line. Using a piggyback ECU I think is the only way forward I can see so far.
  20. andavaka
    andavaka Member
    37
    Apr 16, 2012
    ZA-Benoni
    Car:
    What further problems do you forsee with the remap on the STD ECU and 2ndly which piggyback systems will work on the Merc.
Share This Page
