NW_Merc
Banned
- Sep 3, 2005
- Location
- Over here, sometimes over there
- 1994 Mercedes C180 classic
Problems with the remap are to do with fuelling. If the system runs lean then the possibility of increased temperature and pistons melting increases. Koolvin had this issue when he first fitted his turbo kit. It was running lean and he therefore decided to run a piggyback ECU with an injector driver.
The simplest (some people like them, others dont) is an aquamist ERL MF2 injector driver which is easy to set up. Some people on Club202 have used the Apexi-AVCR. Standalone would be the way to go, but from what I have read, this is not feasible as the standalone ECU can't interface with the gearbox ECU (if your car is an automatic which mine is).
I sent an email to gauge what was possible to DTA Ltd and here is the answer I got:
"An S60 will run your engine perfectly well but may or may not interface with the rest of the vehicle. If this is a normal road car I would leave well alone, if a competition car then go ahead"
So it comes back to aftermarket fuel management is out unless going down the route of an additional injector.
