I believe the centre vents are fresh air only.
Is the centre vent thumb wheel turned on to open the vent?
What year is the car?
Dec
Could you put up a picture of the area of your dash like the area in picture below?
I wonder is the right hand air direction dial working, its set at 8 o’clock, any change if you turn it to say 4 o’clock?
Are the side vent air flow strong when motor is on full blast at setting 5?
It's winter here, how can you tell if the AC works?
Will the recirculate button, with engine running, make any difference… bottom of the four buttons with car image?
Was the heater control unit ever removed recently?
Lines look normal, if one wasn’t plugged in then it would be hanging loose somewhere, example of another C180 1994 below.
When the heater control unit is removed, sometimes it is not put back properly, sometimes one or both of the 2 pegs on the rear of the unit are not re-inserted correctly into there respective tubes. If that is the case then correcting this issue might have a bearing on your problem, however, both pegs might indeed be in place and aren’t the cause of your fault, so you might be wasting your time checking this out.
The only way to check is to remove the unit, slowly, to see if both pegs are indeed in their tubes. When the right dial is turned, the air distribution is altered by the 2 pegs.
There is some removal information about halve way down this page under Wood Trim and Climate Control, note, not your particular model see here… With this post
Dec
GUESS WAt? I'TS ONE OF THE VACCUM HOSES, I LOOKED BACK THERE, AND THE PLASTIC GREY HOSE THE RUNS BEHIND THE BLOCK AND DOWN, WAS LOOSE, I LOOKED AT IT, AND FOUND IT JUST HANGIN, SO I WILL CONNECT THAT BACK IN TMORROW
MY BUDDY HAS THE SAME CAR AS ME I LOOKED AND FOLLOWED WHERE HIS HOSE WENT, THERE IS LIKE A SECTION THAT THE HOSE SLIDES ONTO. IT'S PRETTY MUCH UNDER THOSE SET OF BLACK VALVES ON THE RIGHT SIDE OF YOUR BLOCK. I PUT MY HOSE BACK ON. THE CENTER VENTS BLOW AIR!!
