Hi
The car has been stood for over 6 weeks whilst i was recovering from my operation
When I finally started it, i eventually realised that there was NO Heat coming in the car !
The engine temperature was sitting at less than 20 degrees all the time, the dashboard was at... -2.0 to 3.0 degrees ......so if i was driving, it would be less than 2.0, and if i was stationery with the engine running it may go up to 4.0degrees... (and that is still... COLD)
It was suggested by members that my Thermostat is stuck in the open position, and is faulty and will need replacing
I have replaced the thermostat and the engine temperature is now always around + 87 degrees (approximately), so this means that my previous thermostat WAS in fact faulty, and the old thermostat had a rattle coming from it too.
HOWEVER....However, although the engine temperature has now gone up to > 87 degrees...... nevertheless i am not getting any heat in the car....Please someone help...we are FREEEEEZING !.......As the thermostat has been replaced, i thought it could be an electrical problem, which is not allowing the heat to come through...Hmmmm ...
Please indicate how to bleed the airlock in my system also
