Another karcher bites the dust
Discussion in 'General Discussion' started by mercmanuk, Feb 24, 2007.
  1. mercmanuk
    mercmanuk Hardcore MB Enthusiast
    1,211
    Sep 29, 2003
    MIDDLETON MANCHESTER
    Car:
    C180 AVANTGARDE SE SPORT GONE AND MISSED LANDROVER FREELANDER 2 LET IT SNOW LET IT SNOW LET IT SNOW
    my karcher seems to have developt a fault,worked fine the last time i used it ,tried it today and it pulsing on and off,then after say 10 pulses or 15 seconds it works fine for a minute then starts to pulse again.theres no kinks in the water supply hose
    any ideas what the fault may be!
  2. Howard
    Howard Hardcore MB Enthusiast
    18,624
    Apr 23, 2004
    Toad Hall
    Car:
    CLS 500 / A 150
    FWIW , at Dads marinas we have a total of about 500/600 metres of hardwood pontoons approximately 7 feet wide , and we bought one of these two years ago from Machine Mart ..
    http://www.machinemart.co.uk/shop/p...0psi/path/domestic-power-washers/brand/clarke
    It's in pretty much constant use, cleaning the decking, washing off slime and bird poo and generally keeping everything clean ... Also used for washing boats and cars and just about everything ....
    It's run on river water supplied by a pump sometimes (when we are in drought), sometimes on the normal tap and takes whatever we throw at it...
    Never given us a days problem and it is in pretty much constant use ...
    I wouldn't hesitate to recommend it to anyone !
  3. GRAV888
    GRAV888 Hardcore MB Enthusiast
    6,503
    Mar 5, 2003
    Rochester (Kent) &Lanzarote
    Car:
    BMW M Sport
    Check the inlet filter where the hosepipe goes.
    You need to unscrew the connector.
  4. Subyland
    Subyland Hardcore MB Enthusiast
    576
    Oct 30, 2004
    Norfolk, UK
    Car:
    E320T; E270T CDI; A170L CDI auto; Land Rover Defender 110
    I have been using a Kränzle machine. It's the MB of pressure washers. Never had any problem.
  5. KLP 92
    KLP 92 Hardcore MB Enthusiast
    2,671
    Nov 28, 2003
    London
    Car:
    Mercedes S600, SL600, C250TD
    I've had the same prob with all my previous Karcher's.
    I think you must be one of the lucky ones if your Karcher actually works for long.
  6. GrahamC230K
    GrahamC230K Hardcore MB Enthusiast
    9,832
    Jul 14, 2002
    Car:
    Audi A3 & S4 quattro
    I'm sorry. A pressure washer that rusts is just bad design.
    :eek:
  7. big x
    big x Hardcore MB Enthusiast
    1,193
    Aug 8, 2004
    somerset
    My 1989 Karcher is still going strong.I seem to remember it was expensive in those days perhaps the build quality was better then.
    adam
  8. Satch
    Satch Hardcore MB Enthusiast
    3,450
    Nov 24, 2003
    Surrey
    Car:
    S211 E320Cdi Avantgarde Estate & Toyota Land Cruiser
    Had my Karcher for 5 years and in that time had a lot of use.
    No problems at all as long as I do not use one of those waterstop hose connectors for teh water supply.
  9. BarryS
    BarryS Hardcore MB Enthusiast
    151
    Oct 6, 2005
    Wokingham
    Car:
    CLK 270CDI
    Have the same pulsing on/off problem too with my Karcher.
    Good suggestion re the water-stop connector - I do use one. I'll try with normal connector next time, thanks Satch.
  10. kelvyn
    kelvyn Member
    42
    Feb 23, 2007
    Luton Beds
    Car:
    W202 C200, Saab9000 lpt
    My Karcher pulses too but only when its not actually squirting pressurised water. Its fine unless you let go of the trigger, it also wont pick up cleaning solutions through its pick up.
  11. BTB 500
    BTB 500 Hardcore MB Enthusiast
    17,007
    Aug 7, 2005
    Berkshire
    Car:
    R129 SL500, 639 Vito 120 Dualiner Long, S203 C230 Avantgarde SE Sport
    I've just 'inherited' a Karcher (says "300" on it, IIRC) with no instructions, will have a play this weekend.
  12. Tomandjo2
    Tomandjo2 New Member
    28
    Aug 2, 2007
    I have same issue with a K4.99, Karcher suggested it was an Airlock or sticky valve and recomended following.
    Disconnect High Pressure hose from washer
    Connect mains water supply
    Let water run through washer freely for 5 mins (switched off)
    Re-conncet high pressure hose and expell air
    Turn on and all should be ok.
    BUT
    didn't fix mine
    I have stripped down and can't find any thing wrong with valves or seals, looking to possibly replace cylinderhead (£11.99 from espares)
    Espares.co.uk only sell genuine Karcher parts and also show exploded diagrams of ALL models
    Tom
  13. verytalldave
    verytalldave Hardcore MB Enthusiast
    3,586
    Aug 26, 2007
    Bromley, Kent
    Car:
    W203 C200K Cubanite
    My Karcher is now about 14 years old and has never missed a beat. I bought it trade before the likes of B&Q and Homebase started selling them.
  14. television
    television Hardcore MB Enthusiast
    12,270
    Oct 5, 2006
    Dorset on South Coast
    Car:
    R230 SL500
    One thing that happens to Kärcher washes when they start pulsing after a couple of year is that they do not accept the full mains pressure, reducing the pressure via the house stopcock works well on the ones that I have including a 650 and a 110
    I too have stripped them down and found nothing wrong
  15. verytalldave
    3,586
    Aug 26, 2007
    Bromley, Kent
    Car:
    W203 C200K Cubanite
    Throttling back the house stopcock doesnt reduce the pressure, it reduces the flow. To reduce pressure, you need to install a pressure reducing valve.
  16. television
    12,270
    Oct 5, 2006
    Car:
    R230 SL500
    You are correct, but it works, this fault and cure works on the auto switch off in the handle moels
Share This Page
