brucemillar said:Ash I spent large parts of my youth 'between the jumpers'. As a result, I would often end up with broken or damaged digits. I'm afraid it is usually a 'wait & see' process. Little can be done to aid the healing process (after you have sought medical help). Keep away from 'Tommy the Tank'
Unable to entice anyone on here to go to Bredbury, (see above) we tripped along ourselves today and came back with this .
Made in 2000 and 1 of 1000 worldwide.
This was the first Gibson standard production model to feature BurstBucker pickups - on this model the pickups are exposed with a reversed zebra pickup in the neck position. It's believed these were wired to reproduce the out of phase wiring in Moore's Peter Green Les Paul.
No more for now (hopefully ).
They do have a lovely tone, does it weigh a lot?
We're away at the mo, but he thinks it's about the same as the Custom and the Goldtop - i.e. not chambered.
I forgot to add, the signed pickguard was with it, in the case - they were supplied but not fitted, as GM played his without it. Many get lost along the way.
I remember seeing these for the first time at the Music Live exhibition at the NEC when they were launched. Some examples on the Gibson stand had very dry fingerboards which was a bit off putting to be honest. Pretty sure these had Burstbucker II pups (Alnico II magnets), so quite low output giving a 'sweet/softer' tone than some of the higher output pups.
Not sure about whether they had the out of phase 'Greeny' wiring, but that would make sense.
Played one somewhere around 2001-2002, very nice guitar, chunky neck too and appreciating in value now.
As for weight, probably 8-9lbs would be my guess.
The reason I asked about the weight was that I was offered a very nice Les Paul a long time ago, it was made at the old factory and was one of the first Gibson Custom shop guitars but when I picked it up my thoughts were how can anyone hold one of these for an hour plus. I'll have to look through my buying journal and see what model it was.
The only way to know the weight is to weigh the individual guitar.
From what I've seen, they range anywhere from 7-11 lbs. My 2002 Standard is 9lbs, it has nine hole (Swiss cheese) weight relief, which was used I think from the mid 80's until about 2007/8 when they introduced the modern weight relief system which removes more wood. I can wear it all night, mainly because it balances well.
More recently, some production Lesters are solid, some have Swiss cheese and some have modern weight relief.
Some of the lighter chambered ones I've played (Les Paul Standard Faded, Les Paul Studio Faded) have been neck heavy which just kills my left shoulder in 10-minutes. That's one reason I don't like the Gibson SG, as I find them to be neck heavy.
The custom shop guitars are from what I've read, either solid or chambered. The solid ones use (at least) use lighter mahogany than the standard production guitars.
