chrisk2010
With hard wax only do small areas and apply thinly don't get to excited when ... i have only ever really used simoniz hard wax.
Applying too much it will build up quickly on your cloth which will result in smearing or trying to do a large area like will also result in smearing.
Now everyone will laugh at this part OR think i a genius but the day before i use it i put it in the fridge i find it makes it harder with less "glooping" but you need to work it a little to get going, i do this more in the summer than winter. I don't about Bilt hamber but i have just ordered one as it had good reveiws on auto express so not sure if i'll use the chill technique until i see it.
Make sure you turn the cloth all the time and change it reguarly to i have a bag of 30 cloths i use and i use different cloths for each panel.
I use one to apply, one to remove and one to buff. It's sounds hard but really the cleaner the cloth the quicker the work.
Lastly with hard wax if you drop or get dirt on the pad / cloth your applying with do not carry on using it dirt will get stuck in the tin and you'll have to bin the tin. #lowerpartofthecar
