- May 10, 2006
- Location
- Preston, Lancs
- S204 C220CDi Sport ED125 (Mr) Kia Picanto Domino 1.1 (Mrs)
Can anybody confirm/help please on an old post from Alfie? A pic or a “back of a fag packet” diagram would be fantastic!!
This only applies if your car is an A/B/C/ML/GL/R class car...... Pin 7 on the white 12 way connector is antenna power from the NTG 2.5. This needs to go to Pin 13 on the main original quadlock connector which is where your antenna amps are expecting the power from.
My layman understanding is:
So I need to put a piece of wire between the 2 places - one being in the set of the rectangular pins (13?) using a small spade connector and the other poked into pin 7 on the white connector. Or should I be more sophisticated than “poke”? What gauge wire would I use?
Many thanks
Many thanks
