Audio 20 question
holbay
Glasgow G73
2003, E320 cdi estate, W211
My car has a Audio 20 cd player can anyone say if the 6 disk indash changer mp3 version will connect and work on my head unit. Thanks..
The audio 20 head unit has the cd changer controls and when pressed display states no changer present so the fibre optic connections must be on the back of the head unit, so i reckon the changer should connect and work. Not unless someone has already tried and failed...
Easiest way to check, before you spend money on CDC, is to take the Audio 20 out and see if there are MOST connectors present. You can then get the changer and optical cables from breakers or eBay ...
