Used but in very good condition.
Engine, Airbag, ABS & A/T Scanner
These MD801 series scanners cover the largest range of worldwide built cars on all the major modules for an entry level scanner. Out performs many more advanced tools at a fraction of the price. The tool covers engine, airbag, ABS, gearbox and live data on all the listed manufacturers vehicles. It will read fault codes and display them along with the fault code definition on-screen. Once diagnosed the fault code can then be erased which in turn will extinguish the relevant light on the dashboard. It will also cover the engine module on any other OBDII/EOBD/JOBD compliant vehicle meaning that you can read and clear codes relevant to the engine or MIL light. It is also able to show codes in dealer code and actual words e.g. "Camshaft sensor position 2 - P01234"
20 manufacturers in 1 tool
Simple to setup and use this tool can be ready to go in seconds. This is a standalone tool that everyone from DIY to professional garage mechanic shouldn't be without. Used all over the world by motor traders and garages alike, this is the tool that professional mechanics don't want you to have!
Check the list of manufacturers further down this listing and if your car is between the years shown and has the manufacturer listed then this tool will cover your car. If not then either click on the 'which tool do I need?' link above or simply contact us with the make, model, year and fuel type of the car in question and a brief description of what you want to be able to do and we will be more than happy to advise of a suitable tool.
*******IMPORTANT:
You will receive a MD801 scanner
FEATURES:
Troubleshoot and clear engine, transmission, airbag, and ABS failures for major vehicles
Global OBD II/EOBD coverage(US, Asian & European)
Turn off engine, transmission, ABS, airbag warning lights
Support all nine test modes of the latest J1979 OBD II test specs, including Read Codes, Erase Codes, Live Data, Freeze Frame, I/M Readiness, O2 Mon.Test, On-Board Mon.Test, Component Test and Vehicle Information
OBD II repair information
Display DTC definitions on unit screen
Retrieve ECU information (VIN, CIN and CVN)
Data graphing
Read, store & playback live data
CAN enabled with no adapters to buy
Memory/battery backup for off-vehicle data review and analysis
Extremely easy to use and highly reliable
Vehicle Coverage :
Audi 1990 - 2008
BMW 1993 - 2008
Chrysler 1996 - 2008
Citroen 2001 - 2008
Ford 1996 - 2008
GM 1990 - 2008
Honda 2001 - 2008
Mazda 2001 - 2008
Mercedes 1995 - 2008
Mini 1993 - 2006
Mitsubishi 2001 - 2008
Nissan 2001 - 2008
Peugeot 2001 - 2008
Renault 2001 - 2008
Seat 1990 - 2008
Skoda 1990 - 2008
Toyota 2001 - 2008
Vauxhall 2001 - 2008
Volkswagen 1990 - 2008
Volvo 2001 - 2008
+ OBDII / CANBUS Standard engine scanning on all other compliant manufacturers
Contents:
Handheld Scanner tool
OBD II Smart connector
Extension cable
USB cable
CD software
User's Manual
Nylon carry case
£76 incl Delivery
*******IMPORTANT:
FEATURES:
Data graphing
Vehicle Coverage :
Audi 1990 - 2008
BMW 1993 - 2008
Citroen 2001 - 2008
Ford 1996 - 2008
GM 1990 - 2008
Honda 2001 - 2008
Mazda 2001 - 2008
Mini 1993 - 2006
Nissan 2001 - 2008
Peugeot 2001 - 2008
Renault 2001 - 2008
Seat 1990 - 2008
Skoda 1990 - 2008
Toyota 2001 - 2008
Volvo 2001 - 2008
Contents:
Extension cable
USB cable
CD software
User's Manual
Nylon carry case
£76 incl Delivery
