Felstmiester
- Jul 17, 2013
- Range rover sport
Had a nightmare the past year with rubber on the c63. First one was a blow out while traveling up to the MLS day a while back witch disintegrated a large portion of the inside wall. Then a couple of weeks after that the other rear developed a bump in the middle of the tread. This wasn't so bad because I was still running the odd make rear I replaced on Msl day so just went and brought a set of conti's. Now today I've had a front tyre literally go pop. It's somehow blown a chunk of bead out on inner wall.
I don't use the car much. Prob a blast one day a month. Sometimes a little more and sometimes less. Every time I take her out I check tyre pressures due to fact it's been sitting and normally put 38psi in.
Dread to think what would of happened if I was travelling at speed when the front tyre went pop. Luckily I was plodding as I had the mrs n kids with me.
Hope this is just a bad year for me and tyres??
