A207 2010 with a battery sensor on the -ve terminal. Replaced battery as it was not holding charge and was the original. New battery and checked voltage engine off 12.4 and engine running 13.9 - 14.1. All good.
With a volt meter in the power socket and whilst the voltage after start is 13.9 - 14. After about 10 mins it drops to 12.4. There is probably about .2v loss at the power socket so driving around it never goes above 12.4 even with every electrical load on.
After a stop with lights on and giving the battery a drain the cycle repeats high volts after start then steady 12.4 at the socket. Battery does not seem bothered about this and car starts no problem.
My 2010 ML after start stays at 13.9. Which is normal behaviour.
The A207 is an E500 with no mention of blue efficiency.
Can anyone advise if this is normal for alternators with a battery sensor?
