Bent spoiler.
babyblueCE
300 CE
Does anyone know why the spolier on the 300 CE dips down in the middle or is it meant to be that way?
Defo not meant to be that way.
Either it has wilted in to sun!! Or some kind soul sat on it once upon a time.
Yes, in days of old when I ran E36 BMWs (1991 > 1999), you'd often see the cheap spoilers sagging in the middle whilst the genuine M sport ones (and better aftermarket ones) stayed true.
anyone know where i can get a new one, or remove it all together?
If you do bin it - you will need to fill in some holes.
If you don't find it too offensive, might be easier to replace...
If you are brave , you can probably bend it back into shape.
Take it off the car and heat the centre of the spoiler with a heat gun and gently bend it back to shape. It's ABS plastic so will go again if you are careful.
Honestly , it won't be as difficult as you think.
I'm forever having to heat and bend my front valance back into shape where i catch it on kerbs ! :crazy:
I will try heating it with a heat gun and mould it back into shape, have seen a cheap one on ebay for around £25 delivered, one of the mount areas needs some attention but a minor fix nonetheless.
It could be all the downforce bending it ;)
