Ok Peeps, Car is my 2002 w211 e55k
What i thought would be a 45min job has turned into abit of a nightmare.
The Upper ball joint on the front nearside of my e55k has completley worn out and its all apart of the arm not separate like the later ones.
I read up previously on the job but failed to think that having Airmatic things would be different.
Basically the 2 retaining bolts that hold the top Suspension arm are too long to pass by the back of the airmatic strut.
I've tried to slacken off the 3x 13mm topmount nuts and remove the lower strut bolt to wishbone, so i can have more movement in the strut to allow the bolts to pass but this is not enough.
So i have 2 options,
1st Try and get a small hack saw in the and cut the top retaining bolts off and pull them through the other way then replace with new.
Or release the Air strut completely (Just enough) so it drops through the tower allowing me to gets these bolts out being carefull not to damage the airline.
I haven't the software to depressurise the system so need to keep the strut connected (air wise). Can i disconnect the electrical plug on the strut or will this cause issues?
Any helps advise would be really appreciated, And its one of those "learn" by your mistakes type thing that i'm going to have to do.
