Blackberry UHI cradle thingy...
I currently have a 6310i cradle fitted to the Comand/telephone thingy in the M Class. I want to be able to fit a Blackberry. Can anyone confirm if this is the bit I need?
http://www.comandonline.co.uk/product.php?productid=16262&cat=0&page=1
Many thanks.
Your ML is a 2001 car so no this is not the correct part.
The only option is to go for the Viseeo MBU-1000 cradle which sits in the 6310i cradle you have. This will give you bluetooth connectivity to the Blackberry.
Hope this helps,
Hope this helps,
Thanks for that. I really would like something that charges as well. Also, this was Richard's car and I wondered if he had upgraded the Comand system in any way?
Clutching at straws......:D
PS.
:eek:Just seen the price of the Viseeo thingy :eek:
Ah ha. Okay, then you have UHI in that car. Probably the only one in the country/world of that year!
Although the Blackberry cradle will clip into the UHI you have, I'm not sure if it supports D2B based UHI. I suspect not but Richard will know for sure.
EDIT: PS. We can do you a deal on a Viseeo i'm sure ;)
Thinking more about this, you can use the MB2 viseeo instead. Its also a lot cheaper ;)
Hi
You can not use any of the Mercedes cradles that use HFP bluetooth protocol as they will echo - this includes HFP, Blackberry cradles, iPhone cradles.
You can use the SAP cradle (but thats very Nokia specific but will nicely use the external aerial on the car) - and of course as Alfie suggests the MB-2 which is the most sensibly priced.
To be exact, your ML has the UHI system (as fitted to 2004 onward ML) and Linguatronic.
Richard
about to PM you
