blitz500sl
- Jan 5, 2013
- Location
- Basildon, Essex
- 92' R129 500SL - 04' E500 Estate - 09' Smart 451 CDI
Brand New boxed Bilstein B12 Pro-kit for the W203 C-Class and W209 CLK
Comes with Four Bilstein B8 Monotube shocks and 30MM Eibach Lowering springs with associated bolts and hardware. This is best road suspension kit around. Much better then cheap nasty coilovers.
Bought this for my CLK but never got round to fitting it.
They fit the following
MERCEDES-BENZ C-CLASS (W203) C 240, C 270 CDI, C 280, C 3.5, C 320,
C 320 CDI, C 350 (05/00-02/07) spring pads must be observed; Spacers required for several wheel/tyre combinations; Conditions see certificates
VA: lowering (expertise): 30 mm; axle load to: 1130 kg
HA: without ride height adjustment; lowering (expertise): 30 mm; axle load to: 1170 kg
MERCEDES-BENZ CLK (C209) 240, 270 CDI, 280, 320, 320 CDI, 350,
500 (06/02-05/09) spring pads must be observed; Spacers required for several wheel/tyre combinations; without electronic suspension control; Conditions see certificates
MERCEDES-BENZ CLK Convertible (A209) 240, 280, 320, 350, 500 (02/03-03/10) spring pads must be observed; Spacers required for several wheel/tyre combinations; without electronic suspension control; Conditions see certificates
Im asking £410 collected from Basildon Essex or can arrange delivery. Im often in London so guess I can drop it off in the area.
