Hi all!
I need some help. Recently discovered a fair amount of water in the side compartments in my 04 c180k coupe. I can't for the life of me find where the water is getting in. If I reach isnide the panels that give me access to rear lights etc the inside of the panels are SOAKING as far up as I can reach. Has anyone had this issue or know of anything I can check? Also it's the panoramic sunroof model if that helps but it doesn't seem to be leaking as the water is located only in the rear.
