C350e charging system corrosion poll
Discussion in 'General Discussion' started by Dodgy, Oct 17, 2016.
How long have you had the car and have you had corrosion in the charging system?
Poll closed Nov 16, 2016.
  1. 12 months plus, no problem
    4 vote(s)
    13.8%
  2. 12 months plus, with charging corrosion
    1 vote(s)
    3.4%
  3. 6-12 months, no problem
    13 vote(s)
    44.8%
  4. 6-12 months, with charging corrosion
    4 vote(s)
    13.8%
  5. Up to 6 months, no problem
    3 vote(s)
    10.3%
  6. Up to 6 months, with charging corrosion
    4 vote(s)
    13.8%
  1. Dodgy
    Dodgy Hardcore MB Enthusiast
    337
    May 11, 2016
    Car:
    C350e
    There have been so many reports of corroded cables in the charging system of the c350e, I wonder if we can get a feel for what proportion of us have had the problem...
  2. derekthetree
    derekthetree Hardcore MB Enthusiast
    270
    Dec 17, 2015
    Car:
    C350e
    Mine gave up charging after 6 weeks of ownership. Was in dealer for a month waiting bits but not skipped a beat ever since. Due it's first service next week so will see if that shows anything
  3. JulesFB
    JulesFB Member
    33
    Jul 8, 2015
    Worcester Park
    Car:
    C350e
    Charge mine outside in all weathers and no issue so far.
  4. CaptainChaos
    CaptainChaos Hardcore MB Enthusiast
    525
    Jul 4, 2016
    Yorkshire
    Car:
    C350e PP Estate
    Does this poll come with a piece of wood to touch when voting? :rolleyes:
  5. JAT350e
    JAT350e Active Member
    84
    Nov 17, 2015
    Car:
    C350e & Sierra Cosworth 4x4
    What really annoyed me was the cable was faulty after 5 months and they had no facilities to check so I had to find a 16A charge. Then when i proved it was the cable I asked if a 8M one could be given instead of a 4M since i waited 3 weeks.
    I ended up with a 4M cable as the said its like for like.
  6. OP
    OP
    Dodgy
    337
    May 11, 2016
    Car:
    C350e
    33% so far! Forget the piece of wood - I'm off to find a Bible to pray that this is a statistical aberration due to small sample size...
  7. OP
    OP
    Dodgy
    337
    May 11, 2016
    Car:
    C350e
    5 out of 16. There must be a few other c350e owners out there...
  8. Saxon6
    Saxon6 Hardcore MB Enthusiast
    107
    Sep 24, 2015
    Car:
    Alfa 4C, C350e
    As an early owner mine was one of the first to corrode. It is a known problem and should be a recall. It's not a case of if, but when.
    Since the new loom has been fitted all is well :thumb:
    I would suspect that cars manufactured from early 16 will have the modified wiring.
  9. OP
    OP
    Dodgy
    337
    May 11, 2016
    Car:
    C350e
    It's good that yours is trouble-free now, but if I'm reading this right, over half the people who took delivery in the last 6 months have reported a problem. It doesn't look like it was fixed until well into this year, if indeed it has been fixed at all...
  10. quonker
    quonker Hardcore MB Enthusiast
    233
    May 11, 2015
    West Midlands
    Car:
    C350e Brilliant Blue, Premium Plus
    Ditto!
    Since mine was repaired have had no further issues.
    Now at 27K miles and all is well.
  11. RRLJO
    RRLJO New Member
    14
    Aug 11, 2015
    Northants, UK
    Car:
    C350e estate & Mini Cooper
    I've had my C350e for about 11 months and it has recently developed a fault where it will not charge from the plug in socket, is this likely to be the corrosion issue referenced here? It still charges whilst driving.
    The car is going in to mercedes anyway in the next few days for its first service so hopefully they can take a look then but it would be helpful to understand what the problem might be so any advice would be appreciated.
  12. pawkins
    pawkins Member
    57
    Dec 11, 2015
    Car:
    C350e Estate
    Had mine 9 months with no issues so far and charge in rain, after seeing initial reports I am careful to try not to let water ingress and even wipe around the connection when I unplug... fingers crossed !!
Share This Page
