brucemillar
- Nov 18, 2010
- C55 AMG Wagon - W124 300te 4matic Wagon - BMW 4.8is X5 E53 - SWB Pajero 3.5 V6 24v
Friends
My C55 is laid up for the winter and kept garaged and healthy on a maintenance battery charger etc.
Yesterday I removed the air box to clean it and fit new filters.
On refitting it and starting the car!! The car runs and ticks over fine. Then when I blip the throttle and let the revs drop....They drop too low and the engine either stalls or surges and recovers. I also now have an eml that clears if I disconnect the battery.
A cursory check by removing the air box reveals no obvious issues - pipes off etc. I have noticed that the MAF appears to be loose and I think that the clip that should hold it to the engine is broken? I can't really tell without another car to compare?
I drove it up and down the road and when coming to a halt (everything seemed fine apart from the eml) the car stalled, restarting first turn of the key.
- If the MAF is not sealing to the air box? Would the car behave like this?
- Should I be able to wiggle the MAF about in a way that it may not make a good seal with the air box? Or, should it be rigid in it's mounting?
