Aibonator
- Jun 26, 2016
- C63S Saloon
Trying to fit a dashcam to the new motor. Want to wire it to the passenger fuse panel 301-341. Looked at the fuse map in the fuse box and there is a fuse for the Panoramic Roof. This must be switched 12v because the sunroof won't open if the egnition is off. But there is no fuse in the slot?
1. Am I missing something in the way I'm reading it?
2. Does anyone know if there is a 12v switched live in that footwell fuse box. I've put the meter on all of the fuses and I'm sure they are all constant feeds.
Alternative was to try the drivers side dashboard but I couldn't get the cover off. Felt like either it, or my fingers would break in the process.
Cam is a BlackVue 650. Currently wired to the constant feed. But this cam doesn't have an on/off button, and so is always on, so having to pull the power every night so it doesn't kill the battery.
Thanks in advance.
Thanks in advance.
