Pitts Pilot
Is there a way of increasing the charging rate to the rear battery in my SL?
And would this be a good idea anyway, given that it is a battery designed for low-mid current use, not high current use, like the front engine/starter battery? I'm thinking too much charging amperage might create too much heat, etc?
It all started less than a year ago when I had the existing MB 'stereo' stripped out and a new 'upgraded' audio system installed by Comand On Line. This transformed the In Car Audio/Nav, but the new system does draw a greater amount of power from the rear 'convenience' battery.
I find that if I make short trips around town the folding roof won't work unless the engine is running - low battery voltage. (I did renew the battery with the MB spec' one when the new system was installed, just to be thorough).
The heavy demand on the rear battery is not that surprising as I now have a 700 watt amplifier, and I listen to my music much more than I ever did before (because it sounds SO good! ).
So an upgraded audio system with an amplifier that can, in theory, draw 58 amps from the rear battery at max output (Windows shatter, in nearby houses....) does need a helping hand at the battery end of the setup.
With this in mind, I presume the MB charging unit has a fixed maximum output? So 'turning it up' probably isn't possible?
How about changing the unit for one that 'steals' some current from the front battery? (I would like to avoid upgrading the alternator!)
Has anyone else found that their modern ICE makes greater demands on their car's battery?
Robert
Robert
