Car Ariel
Discussion in 'Electronics' started by Crazyjester900, Sep 6, 2008.
  1. Crazyjester900
    Crazyjester900 Hardcore MB Enthusiast
    510
    Jul 25, 2008
    Melbourne, Australia
    Car:
    C200 W202
    Hi Guys,
    My car ariel does not go all the way down,
    i can hear the motor working for the correct
    amount of time, but the ariel does not go down all the way?
    It does not go up either.... But the motor runs when i turn
    the radio on or the car on and off...
    Someone needs to tell the motor that the ariel is not moving??
    Any idea's?
    Also how do i can to the ariel to check it out?
    any HOWTO guides?
    Brad
  2. OP
    OP
    Crazyjester900
    510
    Jul 25, 2008
    Car:
    C200 W202
    Any Idea's?
  3. Howard
    Howard Hardcore MB Enthusiast
    18,624
    Apr 23, 2004
    Toad Hall
    Car:
    CLS 500 / A 150
    Possibly stripped teeth on the mechanism.
    Just buy a new aerial , they are cheap.
  4. gurpz
    gurpz Administrator Staff Member
    3,724
    Jan 28, 2007
    London
    Car:
    Mercedes C230K Sport
    Yes, VERY common problem you will need a replacement mast but be sure to by a genuine Hirschmann one with H 11 on the tip (correct one for the W202). Its around £20 here in the UK from the dealers.
    Very easy to replace too with the help of this guide:
    http://homepage.ntlworld.com/m.coxon2/areialmast.html
  5. OP
    OP
    Crazyjester900
    510
    Jul 25, 2008
    Car:
    C200 W202
    ok, is it easy to replace yourself?
  6. OP
    OP
    Crazyjester900
    510
    Jul 25, 2008
    Car:
    C200 W202
    so do i need just the mast,
    or the whole thing including a motor?
  7. NW_Merc
    NW_Merc Banned
    5,918
    Sep 3, 2005
    Over here, sometimes over there
    Car:
    1994 Mercedes C180 classic
    You can only replace the aerial mast if yours is an original Hirschman aerial. If it's not then you can buy a replacement car aerial made by Autoleads quite cheaply.
  8. OP
    OP
    Crazyjester900
    510
    Jul 25, 2008
    Car:
    C200 W202
    went and check it has the H 11 on it i'd like to keep it OEM as possible so i'll try track down an original..
  9. NW_Merc
    NW_Merc Banned
    5,918
    Sep 3, 2005
    Car:
    The dealer can supply you with a mast or you can look on ebay, I think they're about 20 pounds here, whatever that works out to in dollars.... It may be cheaper where you are.
  10. OP
    OP
    Crazyjester900
    510
    Jul 25, 2008
    Car:
    C200 W202
    20 ponds is 45 bucks!
    i tried to undo the bolt at the base of the mast,
    it just sheered off and broke, so now it's broke.
    :( fantastic
  11. Spinal
    Spinal Hardcore MB Enthusiast
    4,780
    Sep 14, 2004
    Uxbridge
    Car:
    Smart, S320 and C180 with 3-pointed stars amongst others
    Sorry to bust the bubble, but a H11 mast from a dealer has gone up to £50... I ended up buying one off eBay for £20ish...
  12. jaymanek
    jaymanek Authorised Forum Sponsor Authorised Forum Sponsor
    16,132
    Nov 29, 2002
    Nuneaton Warwickshire
    Car:
    if its getting stuck it probably just wanted some 3 in 1 oil... but now its broke you will need a new one.
    You can buy a "hengst" one from Euro or GSF for around £30-40.
Tags:
Share This Page
