Fivehunnit
- Jun 26, 2015
- CLS63 AMG (W219)
So, I've had a CLK500 (W209) for about 3 months, all was fine until about 4 weeks ago, I went for an overtake, no problem, then afterwards, when setting off from traffic lights and junctions, throttle response was non existent for a few seconds, then suddenly it would shoot forwards, it's also had a sort of irregular idle since a few weeks after I got it, but this got worse after I went WOT for the overtake. Switching off and back on again sorted it, no problems again (apart from the idle, which was sometimes ok, other times a bit shaky) until 2-3 weeks later, again upon WOT, this time, cough cough, all kinds of lights and noises from the dash board, "ESP faulty, visit workshop!", engine check light came on, no throttle response at all, car came to a stop and engine died. This time, upon turning the engine back on, the engine check light stayed on, throttle response was delayed by a split second every time without fail, sometimes it carried on right through until 3,000 rpm or so, other times it was just the split second cough and that's it, sometimes, coming to a stop at lights etc the car would shake, sometimes even shut off.
I had it plugged in at a local garage, which gave codes for "pedal value sensor (short circuit, path 1)" and "MAF sensor".
Having already changed the MAF sensor with a Bosch unit when the problem first happened, I thought it odd, I ordered a new pedal assembly from Mercedes (no part dealers stocked them), put that on, transpires there was no change at all, back to the drawing board.
A few days later, it's in an indy garage who plug it in and get the MAF code but no mention of the pedal sensor, they test the MAF, Potentiometer, throttle body, all found to be fine, they replace any possible wiring that may have been broken inside, no change, they say that the only possibility now, is that the ECU is defective and needs to be sent away to find out if it's fixable, or if I will need a new one, to the tune of £1,400 and 5 working days of delivery time, plus the labour for the diagnostics and work.
My question is, why would the ECU malfunction like that? Is it well known in the M113? I've struggled to find any post where someone had this problem with the W209, lots of older ones and other models caused by oil leaks up wires or ?HT leads shorting? if I get it fixed, or get a new one, is it likely that something caused it and will be ticking away ready to blow it again?
