Central locking clk 209
Discussion in 'Electronics' started by gavinmc, Jan 5, 2017.
  1. gavinmc
    gavinmc New Member
    5
    Jan 11, 2005
    manchester
    Car:
    clk
    Hi all, my car has a flat battery i can open the drivers door using the key blade but i cannot open the bonnet. The ignition is dead. Is there a way to energise the central locking or open the bonnet with a flat battery?
  2. Grotbag1
    Grotbag1 New Member
    27
    Dec 18, 2015
    Car:
    2015 C220 Estate Sport Premium AND 2005 CLK 200K Convertible Avantgarde
    The bonnet release is a lever under the steering column. I thought it was mechanical, not electrical?
  3. OP
    OP
    gavinmc
    gavinmc New Member
    5
    Jan 11, 2005
    manchester
    Car:
    clk
    so did i but it won't release, fuel cap and boot lid are also locked
  4. jotter22
    jotter22 Hardcore MB Enthusiast
    2,248
    Apr 23, 2013
    Gravesend,Kent.
    Car:
    CLK 320 Avantgarde convertible
    The bonnet on mine opens while the battery is flat mechanical as Grotbag has said?
    Tony.
  5. OP
    OP
    gavinmc
    gavinmc New Member
    5
    Jan 11, 2005
    manchester
    Car:
    clk
    just tried again the cable isn't moving just the handle is flexing it appears to be deadlocked. i'll have to try jacking it up and try to release from underneath
  6. PobodY
    PobodY Hardcore MB Enthusiast
    1,525
    Aug 23, 2016
    Stoke-on-Trent
    Car:
    CLK350 Sport, Nissan GTiR
    My bonnet opens when the battery is flat, but not the fuel flap as you say.
    On the Nissan the cable is quite stiff; any chance it's the same problem on your CLK? Try pushing the bonnet down to take some of the pressure off the latch.
  7. KillerHERTZ
    KillerHERTZ Administrator Staff Member
    15,237
    May 21, 2003
    Cambridge
    Car:
    CLS55 AMG
    Mechanical, they do open without battery connected - I did this only last month on the car I was facelifting.
  8. Trickythemerc
    Trickythemerc Hardcore MB Enthusiast
    415
    Feb 1, 2015
    South Manchester
    Car:
    CLK 220 CDI Sport 2009
    The cable or catches could have gone stiff because of the cold temperatures. Try getting another person to push down on the bonnet while you pull on the release.
  9. OP
    OP
    gavinmc
    gavinmc New Member
    5
    Jan 11, 2005
    manchester
    Car:
    clk
    managed it drivers front wheel and well liner managed to pull the cable from there. There is an electrical connection to it maybe alarm still cannot pull the cable from inside the car which i usually can, i will try again when battery is sorted .. Thanks for the replies
  10. OP
    OP
    gavinmc
    gavinmc New Member
    5
    Jan 11, 2005
    manchester
    Car:
    clk
    battery changed still can't pop bonnet cable must be frozen or knackered in the car. thanks.
Share This Page
