Uky
- Jun 23, 2006
- C238 AMG
This is the advice that I got from a friend who works as a prefessional MB Mechanic.
If the battery is bad but not "gone". (It may not apply to yours but changing a 212/207
main battery is not specifically difficult.)
Open the hood.
Open the driver side door.
Down the window.
Close the door but do not lock it
with the remote (or keyless).
Remove all keyless keys well out of range.
Place the normal key out of reach.
Wait for ~20 - 30 minutes. The vehicle should be in sleep mode by then.
Replace the battery, (-) first and last.
(While you are at it, there is most likely a bunch of old leafs under the battery plate
so it could be removed and the area underneath cleaned. Be careful: One of the bolts
is quite short as it is right above one of the AC refridgerant hoses. Make sure you
replace that very bolt with one with same length! (On my 207, those bolts seemed to be
semi-self-tapping. I had to replace all of them)
If the 207/212 has been properly in sleep-mode, there should not be any need
for recalibration. I replaced the VRLA-battery in my 207 following the procedure above.
No problems.
(The opening of the door and window down is just in case something happends with the remote. If that happends, you will be able to get in and drive.)
Open the hood.
Down the window.
No problems.
