More of a tip than question. Anyway battery was flat on the car today because of interior light being left on. There is no way of jumping the car. No terminal under bonnet. Interweb says under passenger carpet and alloy plate there is a jumper point which there isn't. (S class there is). Didn't fancy trying to put power though central locking fuse so.
1. Unlock boot with key and slightly lift
2. Needs 2 people
3. Left both corners of boot lid nearest rear screen SLOWLY
4. Once corners are at opening height gently left boot in the centre only enough to get shoulder in
5. You should then be able to remove cover for battery
Terminal nearest light cluster is negative.
6. Jump start as normal.
Battery terminals are 10mm bolts
Reason for this write up is because I couldn't find any way on google that had a answer for this.
Car concerned is 2001 cl500 with auto (electric) boot open/closer
2. Needs 2 people
