CL500 Maintenance / Preventative Maintenance
Discussion in 'Parts, Maintenance & Servicing' started by Chris Johnston, Oct 12, 2017 at 4:05 PM.
  1. Chris Johnston
    Chris Johnston New Member
    4
    Sep 15, 2008
    Wickford, Essex
    Car:
    2005 Mercedes CL500
    Any fellow C215 CL500 owners out there with advice or little tips in keeping one of these cars running perfect?
  2. Codger49
    Codger49 Hardcore MB Enthusiast
    1,006
    May 21, 2015
    South Kent
    Car:
    W209 CLK500, CLK280; W168 A190; E46 325i
    Well, the snide response would be to be in possesion of deep pockets.
    More seriously, if I were maintaining a 12 year old CL, I would use the forum's often recommended indy's e.g. PCS in Horndean or Wayne Gates in Harrow, or guys who really know their Mercedes such as Philip Tutt of WelwynMerx or Steve Garlick of Stevensons in Maidstone.
    I would also ensure they have the regular servicing business from me to keep them 'onside' and feeling responsible for the car's well being.
  3. clk320x
    clk320x Hardcore MB Enthusiast
    2,088
    Sep 27, 2016
    Northamptonshire
    Car:
    CLK320 W209, AMG styling, Facelifted Dash, 18" AMG wheels, Pioneer SPH-DA120 App Radio
    - Make sure all the maintenance is up to date.
    - Get ATF changed if it hasn't been done in last 36k (if you have the 722.6 5 speed) , change the pilot bushing at the same time. Make sure all the fluid is changed including that in the torque converter.
    - Check the rocker cover gaskets are leak free as this is a common failure and makes a mess
    - check the rear brake pipes are sufficiently oiled to protect them from corrosion as often these corrode and cost £500 to resolve afterwards
    - no harm in changing all the filters etc as soon as you receive the car anyway they are all pretty ****ing cheap from MB
  4. alabbasi
    alabbasi Hardcore MB Enthusiast
    396
    Feb 18, 2008
    The M113 is a pretty robust engine provided that you stay on top of oil changes and use the fleece filter. I usually go 6000 miles between oil changes and use Mobil1.
    Cam covers can leak and spark plugs need changing every 100k miles.
    ABC suspension is going to be the next big expense. If a hose blows, find a hydraulic shop to fix the hose which will be cheaper than buying a new one from a dealer. Also replace the pulsation damper which probably failed and caused the hose to fail.
    Makes sure you flush the ABC fluid at regular intervals and replace the filter.
    Since buying my S55, which has 140k miles I"ve had to replace one blown ABC hose, flush the system and replace all four accumulators. My CL65 only has 34000 miles and has not needed anything.... yet.
Share This Page
