Clk 230 boot problem
BruceC
CLK 230 KOMPRESSOR CABRIOLET
Hi all , newbie on here , so first post , hope someone might be able to help , the battery has gone flat on my 230 clk cabrio , and when i went to open the boot with the key i found that at some point the boot lock has been changed , so the key doesn't fit , so my question is , is there a charge point for the the battery under the bonnet anywhere , or can the boot be opened by any other method ?
Thanks in advance ,
Bruce .
Do you have the below?
Dec
Yep have these points , thanks a lot
Bruce .
Your lock is likely seized due to infrequent use, very common problem.
Will the key fully enter the lock key hole?
Try some WD40 or Penetrating oil.
Dec
will try the WD in the lock , thanks
Bruce
