dotmikes
- Feb 23, 2016
- Mercedes CLK 230K 2001
Hi
I have a fault with my instrument cluster.
everything works fine apart from the lights (behind the speedo)that illuminate when the switch is turnt on.
i have checked all fuses... under bonnet.. drivers side and the boot and they are working/not blown.
intotal there are 4 bulbs that are ment to swith on behind the speedo, I cannot get the 2 larger ones to illuminate what so ever.. i have tested the bulbs and they are fine. but the 2 bulbs that are smaller to either side will not switch off.. they are always on no matter what, even if I remove the fuse that controls the dash!!
I can only think that the speedo is faulty but hopefully I have missed something out that you guys can help me with!!
thanks,
Mike
07969-156-077
thanks,
Mike
07969-156-077
