Buckthorpe
- Apr 2, 2014
- E250 Sport Cab W207
Morning everyone
I have a 2007/57 CLK200K Cab with factory Comand. Most of the time it works perfectly well. Occasionally, when I first get in the car in the morning, it switches itself off and on for about 5 minutes, during which time, none of the control buttons either light up, or work. It then seems to correct itself and is fine. I did have a viseeo fitted in the tel pre wiring so took that out a couple of weeks ago to see if that was doing something. It has been fine since then until this morning, when it did it again. I also have a CD changer which I was using yesterday and when I switched off last night, it was the CD changer that was being used, ie when I switched on this morning, the CD came on, then off, then on etc..you get the picture. Any suggestions gratefully received. Thanks Nick
