Hi all,
I have a rather pressing issue (due to its nature).
I recently bought a clk, it's a lovely car, nearly everything is perfect, but I have noticed that there is a boot locking problem. Here's what happens:
When I use the electric car key and lock the car, the doors lock perfect etc. But, a few days after buying it, being a bit anxious whether everything was closed, I checked the doors (closed indeed), and then checked the boot. I pressed the boot lock in and... it opened! No amount of f*** words helped.
So, below is the list of things I tried:
1) took the metal key out of the electronic one, and tried to lock it manually. To no luck, as it doesn't turn (should it? should it not? - from my understanding of the owner's manual it should). So, I sprayed in the WD40 for the extra magic, but no luck (I did it a few times - nothing happened).
2) Now, I thought - well maybe there's some electrical glitch, so I disconnected the battery, waited a few minutes, connected again, nothing happened.
3) Ok, so fuses left. Checked the fuses (all of them). None was burnt. But, worth mentioning that the car had a few other electrical issues, which I sorted out in a garage (like windows and mirrors not working). Now, two days ago, I thought - I'll go and check the fuses again - the ones in the boot only. Fuse number 5 was one recommended on some forums to be responsible sometimes for the boot problems. Checked it, not burnt. Checked the diagram on the fuse box, it was a wrong fuse in. So, I started to check all the fuses in the boot (a bit of a fuse mess tbh), put them all in the right places, bought some extra ones to put them in order. Then, the engine compartment fuses. A lot of f*** words later, I put them all in order again. Now, this explained to me the previous electrical glitches - some idiot just put the wrong fuses in (e.g. 30A instead of 5A - really makes a lot of sense why things didn't work).
Extra information:
The central console boot opening button works fine. The boot opens when pressing the electronic key. It just doesn't lock.
Any suggestions would be really welcome, before I take it to MB to allow them to rape my wallet.
Extra information:
