Andy Siebs
- Feb 15, 2017
- Clk 230K
I have a 1998 CLK230 kompressor that I am having problems diagnosing what the problem is.
The car itself starts however there is no power and when you try the accelerator, the revs never rise above 2.5k. The kickdown had started not working about 100 miles before the main problem but ist almost as if the car is restricted in running fully. I have tried resetting the ECU incase it was in limp mode but had no success.
I have had 2 garages look over the car and hook it up to a diagnostic machine. Neither could pin point an exact problem. One touted that it was the compressor/supercharger part. The other has suggested changing the injector plugs may solve the problem.
Has anyone had similar issues or maybe able to suggest a potential solution?
Many thanks in advance
