ken.psaila
- Dec 24, 2016
Same problem on startup idle low then continue good. W168 has plugs so sensitive that like to misscontant. Pull out maf both plugs, actuator plug, spartplugs plg and another plug under tha maf...so all plugs follow tha maf plugs main cable. Spray wd40 in all both ends and re plug everything. Spray caburator cleaner in the maf sensor and in you can follow youtube and clean actuator. As i said w168 plugs love loose contact. Startup and go.
Sent from my SM-G7102 using Tapatalk
