MickyP64
So the CVT on our W169 A200T finally gave up altogether!...I've been living in fear that day would come!
I’ve just got the car back after having the Gearbox and Torque Convertor completely rebuilt, so I thought I’d post the findings for others who may find themselves in a similar situation, as I’ve not seen this info posted anywhere else.
Forgive me, I’m not a mechanic but I’ll try to explain what our car has been through lately!
It seems that a common mechanical problem with the CVT found on the A & B Class (W169 & W245) is bearing/shaft wear on the Primary Pulley. Our car has done just less than 60,000 miles, and I’m told that 60,000 to 100,000 miles seems to be the danger zone for this issue.
You can see the Primary Pulley arrangement here - item B01 in this diagram:
The shaft and bearings between the Primary Pulley and the Primary Actuator wear - I’ve taken some photos of the resulting damage to the parts taken out of our car:
The result is that things begin to drift and not line up, and eventually in our case the Pulley/Actuator locked up and could no longer adjust the gear ratio resulting in the car going into limp mode and giving ‘ impermissible transmission ratio’ error codes.
This same issue also results in the drive shaft to the Torque convertor being pushed too far which also results in wear:
Very annoying!...This seems to confirm that some (maybe all?) MB CVT gearboxes appear to develop problems at around 60,000 miles, but comforting to know that you can actually get the transmission rebuilt, even if it is an expensive option (cost just shy of £2500.00). Unfortunately it seems quite possible that it’ll happen again in another 60,000 miles or so.
In addition to all this, I’ve learned that those suffering the dreaded speed sensor failure – you can now get a new ECU separate from the Valve Body which should allow for a cheaper repair. (Incidentally the guy that rebuilt my gearbox has used ecutesting in the past, and didn’t rate their repairs).
I also saw a video on Youtube recently (but can’t find the link – I think it’s one of the Mandy Conception, Automotive Diagnostics & Publishing vids). It suggested that no two CVT units are identical and need to be calibrated when installed – this probably explains why each new ECU needs to coded to the car when fitted.
I now personally feel that although the CVT certainly has problems, it’s not the scary beast I once thought it was. Hope this helps some folks out!
